Shirley
Shirley
- Shirley
- 178
- Member, Administrator, Moderator
@max_eastwood What's the storage capacity of the microSD cards you use? We strongly recommend to use a card that has 8, 16, or maximum, 32 GB of storage. Secondly, we need to know what firmware version your board is running. Two ways to view t…
Thank you for sharing the screencaps. I see identical noise on all channels. Let's try to address this with fine-tuning your set-up and reducing environmental noise. First, see general tips for reducing noise (Cyton and Ganglion boards): * U…
Hi Hiro, I believe the CytonDaisy sample rate is 125 Hz, regardless if you are saving the data to GUI folder or to microSD card. I am surfacing this thread to RW's attention. I will revert with feedback. best, Shirley
To my knowledge, Ganglion firmware has not changed since 2018. See last Github release: https://github.com/OpenBCI/OpenBCI_Ganglion_Library/releases/tag/v2.0.1 Resolution = Voltage level / 2^n n= 24, per the A/D converter MCP3912 specs: http:/…
Hi Felix and William, thank you for bringing up this potential Ganglion board glitch. We scheduled engineer time this week to replicate the issue shown in Felix's screencaps. We'll be in touch about our findings Would like to add - we can send ano…
Thank you for the request. Unfortunately no. The timeline of availability hasn't been solidified. Also, due to the significant difficulties and cost associated with sourcing components in the global situation, the wifi shield price had not yet been …
Hi Jonas, The hardware team has put the wifi shield on the list of near-term projects. Solution testing will soon be underway. At this point we don't know how long the fix + manufacturing of new wifi shield will take. Updates on this product will…
From an exchange between Ioannis and me - Ok let me summarize teknomage’s question/issue: First of All teknomage in his initial message talks about adding a new component to an OpenBCI board, i dont get specifically , to which board, dongle boar…
@wjcroft, hi Ioannis can provide the RFD loader, as he's been helping me optimize the Cyton/dongle programming process. He is on the company slack. -Shirley
@pluto Thank you for your post. i will bring this cyton SD card streaming/recording data issue to the attention of the engineers tomorrow morning. This will likely require a firmware-level fix, and could take weeks. In meantime, can you work with …
@mhadji05 Instructions for Gel Electrode Cap Care Instructions for Gelfree (saline) Electrode Cap Care
Hi SHP students, We use a PCB scaffold to program ganglions. We don't use OTA. The user can follow the instructions to build from source https://docs.openbci.com/Ganglion/GanglionProgram/#building-from-source , and use the linked files here: http…
They're simply different colors to help the user differentiate between 10-20 locations. You can swap out cables as you wish*. *Note William's comment below
@wjcroft thank you for the mention. The wifi shield hardware revision is currently paused due to ongoing time obligations but we have not shelved the plan to bring it back into the shop. Any updates will be announced via the OpenBCI monthly newslett…
Hi Justin, thanks for your post. Have you contacted [email protected]? One of our staff can help you with product questions. best, Shirley
@alwayswearshats Hope you had a nice weekend! I'm reviving this thread to update you on the wifi shield. After reviewing the above comments, it appears the way to go is to remove C4 (100uF ceramic) and replace it with a >300uF electrolytic capaci…
Thank you @wjcroft for the tag. @georglange , hello and thank you for the feedback. The shipping cost for FedEx (and any other ship method) is passed directly to the customer without surcharge. Unfortunately, we don't have control over the rates …
@wjcroft the warning about disconnecting before repeated turns has been added to the Ultracortex doc @ht_steve1976 please email [email protected], we'll keep an eye out for your email. -Shirley
@scipio As you and @retiutut have alluded to, OpenBCI products are not FDA or CE certified, which depending on how your experiment or data-sampling procedure is set-up, could limit the usability of your data/study findings. It may help to refer to t…
@MatthewCaine thanks for the spreadsheet. The micro SD card is the st-tf-003A from SEEED Studios. You can email them directly for a quote. A few things to keep in mind when sourcing a capacitor cross. The alternate part should have the same cap…
I can look into suitable alternate components. Can you provide more information on which board, the specs of the EOL array capacitors (i.e, capacitor footprint, tolerance, rated voltage, etc). I presume you have the part number of the array capacito…
UPDATED LINK FOR ULTRACORTEX 3D PRINT FILES HERE ULTRACORTEX 3D PRINT TIPS AND SUGGESTIONS ** HERE** and HERE
@iqram, please email [email protected] to get in touch about a replacement Ganglion. Thank you
Posting on behalf of a customer: "I was trying to take data from cyton 8 channel kit and feed the data to EEGLab. The issue i am having is with the channel location file (SFP format). Could you please point me to the location from where i can an…
Hello, Re-opening this thread with a new comment on behalf of a customer who is seeing the sawtooth 1Hz noise, and who had previously consulted this thread. She was sent a new Ganglion but is still seeing the 1 Hz noise. "As I started to co…
thank you very much William, I'll bring this to the attention of the customer.
@sofiajh24 what is the shipping address? We will send a new dongle and Cyton
@sofiajh24 We'll mail a cyton with current firmware. Would you please email [email protected] with your mailing address? Thank you
Sofia, hi. Did you try to program either the dongle or the Cyton? By program I mean upload firmware. This is not necessary, and we do not recommend doing this unless you are trying to change the default firmware already on each board/dongle.
Backorders involving cytons, cytondaisies, and print-it-yourself UCM4 have been resolved.
