EEG Mouse Cursor
I have been tossing this idea around in my head for a few months and would like support on going about this. I would like to use the ADS1299 to read my brain signals (preferably not moving my body so prefrontal area?) I'm wondering if the OpenBCI schematics/pcb can be used for this reason. if not how would they need to be altered? Would it be better to disign my own or use a pre-made gerber file on like JLCPCB? The software to control a mouse with an EEG im guessing isnt optimal right now, will i need to make my own?
I am on a fairly tight budget which is why i sugest building my own.
The BCI 'paradigm' you refer to: smoothly moving a mouse cursor via signal processing of scalp detected EEG, is generally considered difficult, if not impossible. HOWEVER, it would be possible to have a monitor display presented to your subject, with four or more on-screen 'buttons' that correspond to actions that you want to execute. For example you could have buttons arranged in a 'cross' showing up, down, left, right. And possibly a center button (for stop for example), or other buttons on the same screen.
By focusing your attention on these 'buttons', the EEG waveforms are produced by flashing each button at a slightly different rate or pattern. The technical name for this is 'cVEP' code-based Visual Evoked Potentials. There are some other Forum posts here explaining how that is setup and programmed. The source code is open source.
Here are some links,
https://www.google.com/search?as_q=cvep+mindaffect&as_sitesearch=openbci.com
https://openbci.com/forum/index.php?p=/discussion/3894/mindaffect-eeg-cvep-bci-robot-control-tutorial-by-pyotr-vozniak
https://openbci.com/community/mind-controlled-robot-openbci-mindaffectbci-maqueen-v2/
https://openbci.com/community/mind-controlled-game-openbci-mindaffectbci-unity/
If you checked some of the 'Community' page links I gave two days ago, and the page 'layout' seemed wonky. Check again, the Wordpress bugs have been fixed. Regards,
