Daisy board not recognized, soldering issues?
Hi
I have a problem on using OpenBCI GUI 16 channels.
When I using only 8 channels It works however when I connected the daisy module and selected 16 channels It doesn't work.
I was using the live mode and when I selected 16 channels the "channel count (8)" correctly change into "channel count(16)"
however when I selected start system it would change into "channel count (8)" and enter live mode.
When I clicked "Start Data Stream" button,. I can't see any signals
Does anybody successfully using OpenBCI GUI in 16 channels?
In Image1, I see overflow pins 21 and 22 on the ADS1299. The same pins are bridged on my 8-bit BCI. Coincidentally, these are both 5V supplies for the analog circuitry. This may have been an intentional bridge.
Finally, there is a bridge between 57 and 58, both are the grounds for the analog circuitry. But, 58 is the charge-pump analog ground. Pretty sure these should not be bridged.
