Cyton dongle blue light won't stay on
I'm trying to use the Cyton board by connecting the Cyton dongle to my PC. When I plug it in, a blue light turns on and a red light blinks. The blue light stays on for about 5 seconds then turns off, and when I try selecting "auto-connect" before and after the blue light turns off, it says "No Cyton dongles were found". I'm using a Windows PC and the Windows version of the software. What should I do to get my PC to read the dongle? The blue light turning off makes me think that it's not physically staying connected at all.
    edited September 2021
    Make sure you have the FTDI driver installed: https://openbci.com/downloads. Found under the section "CYTON DONGLE DRIVERS".
    Has this dongle ever worked correctly? How long ago did you purchase it?
    Maybe the USB port could be broken or not have enough power? You could try another port or a powered USB hub if you have one on hand.
    -RW
  • i have exactly the same issue. Have you solved this problem?
    edited January 2022
    @qijia If you have already contacted official OpenBCI support, you can continue there. On rare occasions, people may accidentally break the dongles or there was a defective part. All hardware is thoroughly tested during the flashing process. In such cases, OpenBCI can choose best how to resolve the issue via official support: [email protected] .
  • Thx. After i got the new one, it worked!
    @qijia Glad to hear this!!! Take Care!
