USB Dongle ejection process
Two very quick questions about the USB Dongle (that connects the CYTON board to the computer)
- Is there a specific ejection process (as with a USB stick?)
- What does the switch on the side of the USB dongle do? It does not seem to be a straightforward on/off
Rod, hi. There is no 'usb disk drive' function in the dongle. You can just pull it out. The switch is for reprogramming the onboard flash firmware.
Hi William, thanks!!
Guess I don't need to fiddle with the firmware unless something stops working.
