USB Dongle ejection process
RodRod Bristol. UK
edited May 23 in Hardware
Two very quick questions about the USB Dongle (that connects the CYTON board to the computer)
  • Is there a specific ejection process (as with a USB stick?)
  • What does the switch on the side of the USB dongle do? It does not seem to be a straightforward on/off
    Rod, hi. There is no 'usb disk drive' function in the dongle. You can just pull it out. The switch is for reprogramming the onboard flash firmware.
  • RodRod Bristol. UK
    Hi William, thanks!!
    Guess I don't need to fiddle with the firmware unless something stops working.
