GUI v5 playback error: "Cannot instantiate underlying board..."
@wjcroft Hi!
Firstly, I have attempted to playback a selected pre-recorded file and failed, getting the following response on the OpenBCI GUI: 'Cannot instantiate underlying board of class OpenBCI_GUI$BoardCytonSerial'. Kindly suggest a solution to this problem.
Secondly, I would like to be referred to OpenBCI documentation that would help me interpret the EEG live data appearing on the OpenBCI panels: for example FFT, Head Plot and Time Series, etc.
Mentioning Richard @retiutut.
re: GUI widgets:
https://docs.openbci.com/docs/06Software/01-OpenBCISoftware/GUIWidgets
There is not enough information here to determine why this would happen. GUI v4 files will need to be converted to GUI v5 format.
Please post a ConsoleLog file and/or share the file in question.
The first 100 lines of a file is also enough to test.
@retiutut The next time I open my computer, I will try to playback the file with the dongle inserted and powered on together with the Cyton. Maybe, that might work. If it doesn't, I will post the first 100 lines of the file. Not sure what a ConsoleLog file is. Thanks.
@Scipio
You do not have to have the Cyton dongle connected to view a playback file, the error message above means it was unable to make a GUI instance of the specific Board class in Java/Processing.
The console log information can be accessed using the button in the top right of the GUI. Here is a picture to show:
@retiutut
Here are as many lines of the file as this discussion box will comfortably accommodate at a go:-
@Scipio Can you also share a console log file when you try to playback this file?
I am not able to reproduce this issue. The file header and data you just shared is valid v5 format.
@retiutut I have finally initiated a playback session with the following Console Log details:-
Nice!
