Failed to start Ganglion BLE Driver
Hey guys, I have a problem with my ganglion board, it use to work 6 months ago.
Now It can't connect and give me the "[ERROR]: Failed to start Ganglion BLE Driver,"
But if I run sudo hcitool -i hci1 lescan I get
LE Scan ...
C0:EC:D2:12:24:2C Ganglion-b39a
C0:EC:D2:12:24:2C (unknown)
Any help is welcome.
This is the log:
Console Log Started at Local Time: 2020-04-11_01-56-05
Screen Resolution: 1920 X 1080
Local Version: 420, Latest Version: 420
GUI is up to date!
OpenBCI_GUI::Setup: Sample Data exists in Documents folder.
The file "/root/Documents/OpenBCI_GUI/Settings/UserPlaybackHistory.json" is missing or inaccessible, make sure the URL is valid or that the file has been added to your sketch and is readable.
Instantiating hub object...
Hub: CheckHubInit: The GUI is connected to the Hub!
sourceList: click!
setInterface: curInterface: -1
channel count set to 4
Setting Latency to 10000
Setting WiFi Internet Protocol to tcp
Setting WiFi style to dynamic
[DEFAULT]: Protocol BLED112 Selected for Ganglion
sample rate set to: 200
Setting sample rate for Ganglion to 200Hz
[ERROR]: Failed to start Ganglion BLE Driver, please see https://openbci.github.io/Documentation/docs/01GettingStarted/01-Boards/GanglionGS
[DEFAULT]: BLE Devices Refreshing
[ERROR]: Failed to start dongle. It may not be plugged in.
I think that I finally discover the issue. I have an CSR dongle, the one that say Bluetooth 4.0.
I need to get the BLE112 dongle.
Should I buy any USB 5.0 dongle or I should buy the one from the store (openbci)?
Im in Uruguay and the post office is really slow right now so if can buy some locally would be great.
@victhor You are correct that the CSR dongle has been deprecated, due to connectivity issues across operating systems.
To get the Ganglion working on Linux in 2020, please use the BLED112 dongle from the store.
OpenBCI is still taking orders and shipping internationally during this time.
Hope this helps!
RW
Victhor, hi.
If you can find the BLED112 from a local distributor in South America, that will work fine.
https://www.silabs.com/wireless/bluetooth/bluegiga-low-energy-legacy-modules/device.bled112
Distributors listed are Arrow, Farnell / Newark, and Digikey. I don't believe Farnell is in South America. Digikey is mainly US.
https://www.arrow.com/en/support/contact-support/find-an-arrow-office
https://www.farnell.com/where-we-operate/
It's possible that Maker / hobbiest companies in your area may stock it.
