Failed to start Ganglion BLE Driver
Hey guys, I have a problem with my ganglion board, it use to work 6 months ago.
Now It can't connect and give me the "[ERROR]: Failed to start Ganglion BLE Driver,"
But if I run sudo hcitool -i hci1 lescan I get
LE Scan ...
C0:EC:D2:12:24:2C Ganglion-b39a
C0:EC:D2:12:24:2C (unknown)
Any help is welcome.
This is the log:
    Console Log Started at Local Time: 2020-04-11_01-56-05
    Screen Resolution: 1920 X 1080
    For more information, please visit: https://openbci.github.io/Documentation/docs/06Software/01-OpenBCISoftware/GUIDocs
    Launching application from local data dir
    OpenBCI_GUI: hubStart: OS Detected: Linux
    TopNav: Internet Connection Successful
    Local Version: 420, Latest Version: 420
    GUI is up to date!
    OpenBCI_GUI::Setup: Sample Data exists in Documents folder.
    ControlP5 2.2.6 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
    The file "/root/Documents/OpenBCI_GUI/Settings/UserPlaybackHistory.json" is missing or inaccessible, make sure the URL is valid or that the file has been added to your sketch and is readable.
    OpenBCI_GUI::Control Panel: Playback history file not found or other error.
    OpenBCI_GUI::Setup: Setup is complete!
    Instantiating hub object...
    Hub: CheckHubInit: The GUI is connected to the Hub!
    sourceList: click!
    setInterface: curInterface: -1
    channel count set to 4
    Setting Latency to 10000
    Setting WiFi Internet Protocol to tcp
    Setting WiFi style to dynamic
    [DEFAULT]: Protocol BLED112 Selected for Ganglion
    sample rate set to: 200
    Setting sample rate for Ganglion to 200Hz
    [ERROR]: Failed to start Ganglion BLE Driver, please see https://openbci.github.io/Documentation/docs/01GettingStarted/01-Boards/GanglionGS
    [DEFAULT]: BLE Devices Refreshing
    [ERROR]: Failed to start dongle. It may not be plugged in.
