Ganglion raw samples with node.js, Python or LSL widget?
Hi All,
I am trying to get access to the raw samples on the Ganglion board. The python SDK included asks for a port (which I presume does not exist for com over BLE).
def __init__(self, port=None, baud=115200, filter_data=True,
scaled_output=True, daisy=False, log=True, timeout=None):
if not port:
port = find_port() <--- this function does not exist
if not port:
raise OSError('open_bci_v4.py: Cannot find OpenBCI port')
I tried using the node js library, but I am unable to get samples out of it (even though it connects and starts streaming). Probably the best will be a LSL widget within the GUI itself in the form of a widget.
Please suggest a solution.
Thanks..
https://github.com/OpenBCI/OpenBCI_NodeJS_Ganglion
There is also a node to Python pathway (NOT the code above which only works for Cyton.)
https://github.com/OpenBCI/OpenBCI_NodeJS/tree/master/examples/python
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Menlo}
span.s1 {font-variant-ligatures: no-common-ligatures}
Bluetooth powered on
Scan started
Found ganglion!
Stopping scan
Scan stopped
Device is advertising 'Ganglion-652d' service.
Found Device: Ganglion-652d
Discovered 3 service characteristics
Found receiveCharacteristicUUID
Found sendCharacteristicUUID
Device is ready to communicate.
Streaming: true Channels: 4 Sampling Rate: 200Hz
Sent stream start to board.
It just gets stuck at that. I have never used JS before but the code looks fine to me. Can someone point out what could be wrong??
Thanks
Please open an issue here and AJ will see it,
https://github.com/OpenBCI/OpenBCI_NodeJS_Ganglion/issues
