Ganglion raw samples with node.js, Python or LSL widget?
AmiyaAmiya Singapore
edited February 2017 in Ganglion
Hi All,
I am trying to get access to the raw samples on the Ganglion board. The python SDK included asks for a port (which I presume does not exist for com over BLE).
def __init__(self, port=None, baud=115200, filter_data=True,
               scaled_output=True, daisy=False, log=True, timeout=None):
    if not port:
        port = find_port()  <--- this function does not exist
        if not port:
            raise OSError('open_bci_v4.py: Cannot find OpenBCI port')
I tried using the node js library, but I am unable to get samples out of it (even though it connects and starts streaming). Probably the best will be a LSL widget within the GUI itself in the form of a widget.
Please suggest a solution.
Thanks..
    Correct, no COM port for Ganglion. Are you sure you were following AJ Keller's @pushtheworld tutorial for node?
    https://github.com/OpenBCI/OpenBCI_NodeJS_Ganglion
    There is also a node to Python pathway (NOT the code above which only works for Cyton.)
    https://github.com/OpenBCI/OpenBCI_NodeJS/tree/master/examples/python
  • AmiyaAmiya Singapore
    Hi @wjcroft ;
    Yes I am following the right one. In fact I can connect to the device but for some reason I just don't receive the 'sample' event triggered.
    See the code below:
    const Ganglion = require('openbci-ganglion').Ganglion;
    const ganglion = new Ganglion({verbose: true});
    ganglion.once('ganglionFound', (peripheral) => {
      // Stop searching for BLE devices once a ganglion is found.
      ganglion.searchStop();
      ganglion.once('ready', () => {
        console.log('Device is ready to communicate.')
        ganglion.accelStop();
        ganglion.streamStart();
        ganglion.on('sample', (sample) => {
        /** Work with sample */
        console.log(sample.sampleNumber);
        for (var i = 0; i < ganglion.numberOfChannels(); i++) {
          console.log("Channel " + (i + 1) + ": " + sample.channelData[i].toFixed(8) + " Volts.");
        console.log('Streaming: ' + ganglion.isStreaming() + ' Channels: ' + ganglion.numberOfChannels() + ' Sampling Rate: ' + ganglion.sampleRate() + 'Hz');
      ganglion.connect(peripheral);
      console.log("Found Device: " + ganglion.getLocalName())
    // Start scanning for BLE devices
    ganglion.searchStart();
    The output is:
    p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 11.0px Menlo}
    span.s1 {font-variant-ligatures: no-common-ligatures}
    Bluetooth powered on
    Scan started
    Found ganglion!
    Stopping scan
    Scan stopped
    Device is advertising 'Ganglion-652d' service.
    Found Device: Ganglion-652d
    Discovered 3 service characteristics
    Found receiveCharacteristicUUID
    Found sendCharacteristicUUID
    Streaming: true Channels: 4 Sampling Rate: 200Hz
    Sent stream start to board.
    It just gets stuck at that. I have never used JS before but the code looks fine to me. Can someone point out what could be wrong??
    Thanks
    Amiya, hi.
    Please open an issue here and AJ will see it,
    https://github.com/OpenBCI/OpenBCI_NodeJS_Ganglion/issues
    Thanks @wjcroft
    Submitted the issue.
    Cheers
  • This issue was resolved with the latest release `0.4.3` thanks everyone for the help https://github.com/OpenBCI/OpenBCI_NodeJS_Ganglion/releases/tag/v0.4.3
