Detecting Alpha Waves
Hi All,
I've been analyzing some data that I recorded from the new OpenBCI V3 boards. These recordings are mostly simple exercises in generating Alpha rhythms induced by closing my eyes. In my previous BCI hacks, I've used these Alpha rhythms to trigger lights and to control robots. I figured that I'd explore in a little more detail different refinements on algorithms to get solid Alpha detection.
Here's the starting point...simple threshold detection:
Chip
http://openbci.com/forum/index.php?p=/discussion/278/alpha-detector-on-board-or-laptop
https://www.google.com/search?q=eeghacker+alpha
I took a quick look at your photos. Did not look at your data. Just from the photos of the OpenBCI electrode wiring, it doesnt look like you followed our tutorial,
http://docs.openbci.com/tutorials/01-GettingStarted#getting-started-w-openbci-v-connect-yourself-to-openbci-2-connect-your-electrodes-to-openbci
In other words, all your EEG electrodes should be plugged into the pins closest to the board. (The IN*N pins). The tutorial picture does show one wire on a IN*P pin, but that is the two wire differential setup for ECG.
Maybe I'm mistaken and you intended to use the IN*P pins for some reason?
http://openbci.com/forum/index.php?p=/discussion/176/placing-electrode-sensors-on-the-scalp
What you need to do is push the hair away from the O1 site on all sides until you can see the scalp skin. Then push down there. I'd also recommend you use an elastic or velcro headband, to guarantee best contact. The scotch tape you show on the hair at O1 is not really that effective for making skin contact.
Otherwise it looks like you are close, keep us posted.
