Does Cyton have guaranteed no missing codes?
Have seen such a description in a couple of places. Not sure if I understand it completely.
https://www.biosemi.com/activetwo_full_specs.htm
The Cyton is using the TI ADS1299 ADC chip. Full specs are on their website, See the 'data sheet' specs on that page,
https://www.ti.com/product/ADS1299
At the default gain, the Cyton has a 24 bit resolution of .022 microvolts per count.
https://docs.openbci.com/Cyton/CytonDataFormat/#interpreting-the-eeg-data
EEG signals below 1 microvolt are generally considered too noisy to have any validity. But the resolution is there. And the default x24 gain can be adjusted to other values if increased upper range is needed.
ADS1299 uses a delta-sigma ADC amplifier. 'Missing codes' may be a misfeature of older technologies.
https://www.google.com/search?q=delta+sigma+adc
Also see,
https://electronics.stackexchange.com/questions/136014/about-adcs-no-missing-code#:~:text=No missing codes is about,codes' about the MSB bits.
