toggle menu
OpenBCI Forum
Sign In
Register
Sign In
Register
Categories
Discussions
Activity
Sign In
Register
Home
profeell
Discussions
profeell
profeell
Username
profeell
Joined
March 2018
Visits
261
Last Active
September 2025
Roles
Member
Activity
Discussions
23
Discussions
EXCEPTION_ACCESS_VIOLATION error from GUI v6.0.0-beta.1
312
views
2
comments
0
points
Most recent by
retiutut
September 2025
OpenBCI_GUI
Does the SD card allow multiple data collections to be saved?
451
views
3
comments
0
points
Most recent by
wjcroft
August 2025
Wifi Shield
Can I use medical ear clips to replace Earclip Electrode?
338
views
1
comment
0
points
Most recent by
wjcroft
June 2025
Electrodes
what is the impedance of Cyton?
354
views
1
comment
0
points
Most recent by
wjcroft
April 2025
Cyton
How to tell whether the ear clip electrode is working?
216
views
1
comment
0
points
Most recent by
wjcroft
November 2024
Cyton
How to connect the cyton board with Arduino?
233
views
1
comment
0
points
Most recent by
wjcroft
November 2024
Cyton
Cyton board channel data samples appear to be DC?
142
views
1
comment
0
points
Most recent by
wjcroft
July 2024
Cyton
how to work Ganglion board by Arduino IDE?
186
views
2
comments
0
points
Most recent by
wjcroft
August 2022
Ganglion
why is Cyton + Shield sample rate, limited to 1000HZ ?
1.5K
views
15
comments
0
points
Most recent by
Rathin63
February 2022
Cyton
Can you help me get the GUI BP Filt 1-50HZ parameter?
212
views
3
comments
0
points
Most recent by
profeell
December 2020
OpenBCI_GUI
why my EEG data is a bigger data?
446
views
12
comments
0
points
Most recent by
wjcroft
May 2020
Software
about Openbci Gui head plot parameter?
463
views
1
comment
0
points
Most recent by
wjcroft
August 2019
OpenBCI_GUI
how can I avoid the time series with glitches irregularly spaced ?
276
views
13
comments
0
points
Most recent by
retiutut
July 2019
Wifi Shield
what command can let me start to record SD card only and no wifi shield.
186
views
0
comments
0
points
Started by
profeell
September 2018
Cyton
Why not publish a new firmware and SDK to support high sample rate SD card recording only?
93
views
0
comments
0
points
Started by
profeell
August 2018
Cyton
cannot get 500 or 1000 hz sample rate from Wifi Shield (or SD card)
2.2K
views
65
comments
0
points
Most recent by
profeell
March 2019
Wifi Shield
the cyton board can connect the WiFishield, I click the 'STRAT SYSYTEM' button, the GUI no work
155
views
1
comment
0
points
Most recent by
pushtheworld
July 2018
Wifi Shield
"No OpenBCI board attached to Wifi Shield", with Cyton v3.1.1, shield v2.0.5
663
views
11
comments
0
points
Most recent by
leevonkraus
October 2018
Wifi Shield
I can`t run the openbci in processing
377
views
0
comments
0
points
Started by
profeell
May 2018
OpenBCI_GUI
how to get cyton firmware versions number?
215
views
4
comments
0
points
Most recent by
wjcroft
December 2018
Cyton
My cyton light no work after it connected the wifi shield
107
views
0
comments
0
points
Started by
profeell
April 2018
Cyton
add a new bandpass filter on GUI to receive 1-100 hz EEG?
1.1K
views
28
comments
0
points
Most recent by
profeell
May 2018
Software
convert EEG data to audio signal
2.8K
views
27
comments
0
points
Most recent by
wjcroft
April 2018
Software
