yourmaverick
yourmaverick
- yourmaverick
- Texas
- 10
- Texas
I did follow the guidance. I think it's more about libraries. I figured that part out. My error looks like a variable "frame" is not claimed before it's called.
By the way, could you please give me some suggestions on my original question about compiling in processing? I got the error "Cannot find anything named “frame”".
Thank you for letting me know.
Thank you for your suggestions. I selected OPENBCI because the GUI is very friendly. I will try other LSL programs later. Really appreciate your help.
Thank you for pointing this out. I was misled by myself. I was trying to do a similar thing to stream the data, but I don't think it would be easy. I will try other approaches to figure this out. Thank you again.
Here's the link : https://www.crowdsupply.com/starcat/hackeeg/updates/hackeeg-and-openbci
They didn't mention if OPENBCI is supporting right now. It was supported, because several people used it and posted online about this. I will try to contact them to see what they would suggest. Thank you so much for your patience. I hope my questio…
I know my port is and I could use the terminal command to steam the data from the serial port. But it looks like I won't be able to input it in the OpenBCI.
Just a quick update: I just tried the OPENBCI_GUI again to stream the data. I just realized my problem was I could not find the serial port in the GUI and I could not manually set it.
Thank you so much for your detailed introduction. Please allow me to spend some time and find out if they are working for my project. Really appreciate your help.
It's not a board like Cyton or Ganglion. They don't have the high sampling rate I am looking for. I am planning to use the Lab Streaming Layer, which was part of the OPENBCI_GUI function, to visualize the data. I noticed in the recent version the p…
Thank you so much for your quick reply. I am new to this. I purchased an EEG kit with ADS1299. In other's sharing, it could be read by OPENBCI. The reason I am trying to compile the GUI is I might need to add addition processing or analysis written…
