yasir
yasir
- yasir
- 13
Hi CHip, Oo perfect. I think I got it a bit wrong. I was thinking one needs some sense of the original reference electrode signal to add it back and then subtract the new reference. Your info makes sense. Thank you all for clerifying the misconcept…
Hi William, Thanks for the info. I am aware why we need a reference signal to record data and use of polar reference methods for recording EEG activity. Your reply helps decide what i need to do though. I should simply decide on my reference first …
Thanks William, You have removed a lot of confusions I had about the data. Now I can get some work done. I get most of what you have explained, but I still see a problem with the reference electrode issue. If I cannot have a record of the reference…
Hey Guys, I was able to edit a test file and simply reduce it to a CSV with electrode output values listed in columns and then opened it in EEGLAB. Though when I plot the signal (2 electrode readings) I simply see two out out of phase sine waves wh…
thanks guys, I will go through with the mentioned options and see how it goes and post some feedback
