Default Avatar
xris
xris
Username
xris
Joined
Visits
25
Last Active
Roles
Member
  • Thanks for your thoughts. No stress, just trying to push projects forward! The only point of emphasis I think I have here is that board fab need not be expensive or time consuming. I figure most or all of us here have the shared goal of wanting to s…
  • You didn't respond to production cost or FLOS points. Granted the hardware is different. But the point still stands that even in small batches the boards could be produced radically cheaper than the purchase price of the OpenBCI boards, without sign…
  • p, li { white-space: pre-wrap; } I appreciate the point that OpenBCI has contributed much, and want to see them succeed because of it. But to assert that building the boards is necessarily expensive and difficult when this is not the case (or doesn'…
  • related: * pull request from: https://github.com/ak1n/V3_Hardware_Design_Files * http://openbci.com/forum/index.php?p=/discussion/1232/new-category-build-it-yourself-under-hardware
  • With clear and comprehensive gerber files and component lists, building should NOT be very time consuming or difficult. All you have to do with those is then order the boards & components, and solder them. I paid something like $100 for board fa…
  • I submitted a pull request with inclusion of gerber files I used, as well as the in-progress BOM list I've been working on (incomplete and no guarantees that product ids or costs are correct). I hope this is useful to others. Any further help with c…
  • These are quite general questions - can you narrow them down? Neurologists specializing in epilepsy are the main physicians who utilize EEG. There is a very diverse array of non-clinical research using EEG for a variety of applications.
