vspuzzler
vspuzzler
- vspuzzler
- 27
Hi thank you for the help. It turned out to just be an issue with the gain value - that slipped me.
Hi, yes I went through the previous posts and tried everything I can find (checking connections, tightness on head, ear clips, and the electrode tips are relatively new). I did switch my electrodes to the Dry EEG Comb, is this an issue?
Ok, thank you.
Would the same method of sodering that I see (https://openbci.com/forum/index.php?p=/discussion/2594/broken-ultracortex-electrode-wire-how-to-repair) here work? I am just a little worried since that models the wire wraps around, while in this one i…
Hi, those seem to be for the earlier models. This is the for the Mark IV headset
Hello, I tested it on a different computer but came up with the same results on auto scan. By chance is it possible that there is anything wrong with the firmware, and if so how do I check it.
Thank you! Will do.
