Default Avatar
vladlolol
vladlolol
Username
vladlolol
Location
_
Joined
Visits
14
Last Active
Roles
Member
Location
_
  • @wjcroft said: I have not studied your active circuit schematic. How is the output from the active buffer connected to the channel and reference. Is there perhaps some anomaly here? I also don't know your op amp configuration. Does it require plu…
  • Output from AE connected to bottom pins. AE have 100Ohm resistor before output pin for protection causes. There is no direct connection to referense, SRB2 pin connected to the head and bias to earlobe. TLC272 doesn't required plus and minus supples,…
  • @wjcroft said: Below is the comment I left for Vlad on an email he sent me: Unused channels can simply be connected to Reference. or Reference and Ground. Open channel pins not connected to any signals, are highly sensitive to noise. …
