tzvet
tzvet
- tzvet
- Hefei, China
- 24
- Hefei, China
I am happy that the openBCI team can help ! I have not tested the suggestions of @wjcroft here or the previous suggestions on the thread i created more than one year ago (or may be even older). But i would suggest that one checks at the end, when t…
@Rafia : if you have already a recorded file it is digital. the cyton/daisy boards are ADCs. For the units, It is normally uV. For a trigger - you need to find your "time stamp of interest". For the "square wave" example i gave, a simple derivati…
Hello @Rafia! I am sorry but what exactly is your question to me ? From your posts it seems that you do have a "working" analog input (out of the voltage issues mentioned by @wjcroft). You need to define carefully the "trigger" input you want to put…
Great! thx!
Good point. But for your proposed test, as i said, the problem is not always appearing. We would need longer or multiple sessions to check it. Have to see. thanks for the help. Best Tzvetomir
William, hi! We bought the system autumn 2017 (Sept-Oct), Cyton+Daisy+electrodes, but somewhere in Jan-March 2018 i re-uploaded a new firmware on the Cyton following a suggestion for solving other issues. It worked. The current Firmware is 3.1.0…
Yes ! Thx.
all fine. succeeded, had to wait some time
ok. release 3.2.0 with SD card writing were made... trying them and closing this discussion.
And last but not least: when using the command /4 for changing the Board Mode to Marker Mode (http://docs.openbci.com/OpenBCI Software/04-OpenBCI_Cyton_SDK) what means: "o 4 = Marker mode - Turns accel off and injects markers into the stream by sen…
Ahhhhh, i recall that the OpenBCI-RAW-...txt IS NOT A RAW VALUE for the system i have: cyton+daisy 16 channels. it is a "smooth"/mean of previous avlues and current measure, because of the limited bandwidth of the connection between dongle-cyton... …
ok, it's Processing... processing.org ... will try to run the source code with Processing under Linux unless somebody is kind enough to make a linux running version
Hello, I need the recorded files on the SD card, with correct time stamps recorded on the AUX channels. the v3.2.0-beta2 is only for MacOSX and Win; v3.2.0-beta3 is only for MacOSX. The source code does not seem for compiling on linux (what type …
Found it ! very sorry for the above post. in case others miss it, it is here : http://docs.openbci.com/OpenBCI Software/04-OpenBCI_Cyton_SDK
Hello, I am looking for a docs summary of available commands for the cyton+daisy, commands for changing basic sampling/channels parameters. is it possible to have a link to the documentation about all possible commands for changing the parameters …
