Default Avatar
tschmitt
tschmitt
Username
tschmitt
Joined
Visits
5
Last Active
Roles
Member
  • Chip and William I am starting on the SD card read with the RTOS system. I do not know witch of the variants I will use. There is a NillRTOS that is very small and may work. At present I am on the hook to get an Arduino interface for a networ…
  • William Thanks. One of the libraries I am looking at essentially sets up an OS which does as you suggest. One thread services the Uart and the other services the sd card. This is new ground for me but the code is well written and I think I ca…
  • Correction Will get a DUE the Mega has the same clock speed. Tom
  • Chip and William Thanks. I will spend next week getting more intimate with some sd libraries. I do need to go to the block writing and to a raw write. I found some alliterative libraries for the Arduino that report quite fast writes. I also …
  • Chip Once again thank you very much. Contrary to your opinion you were very helpful. I will get some chips and "hack up' instead of "hacking down". (after I get this dragon slain). With regards to the sd speed I found some libraries that are q…
  • Thanks Chip. It looks as though I have some study to do. I may get back but will delve in myself for a while, Data collection speed is an issue as the Nyquist limit starts creeping (galloping) up. Do you know how fast the Adroids are at capt…
  • William Thanks! It looks like the ADS129x can be patched into a Teensy. Looks good. I will probably order the kit and a raw chip. that way we will have something to use while fabricating. I will keep your team informed if we manage to get a…
