Avatar
tristanlbailey
tristanlbailey
Username
tristanlbailey
Location
Australia
Joined
Visits
27
Last Active
Roles
Member
Location
Australia
  • It's a secret... I'll wait for AJ's input on the potential configurations of the Wifi Shield and their associated sample rates.
  • Hi William, thanks again for your reply. I do believe that my project requires high sample rates, and as such I am concerned about the ability of the device (and by extent, its connection) to provide high-quality, error-free sample rates. Thus, …
  • "It seems that it is unlikely that the Wifi Shield would ever support Wifi-Direct." Hmm... https://shop.openbci.com/collections/frontpage/products/wifi-shield " * The WiFi Shield currently only supports WPA level security. WiFi direct …
  • Thanks for your reply William, but I think you misunderstood me. I know about the Bluetooth connectivity, as I have used the Mark IV Ultracortex a few times now. So, I was asking if there was a more direct way to connect when using the Wifi Shield…
  • OK, so by "switch" I guess I mean "access point" or "hotspot" (I'm not used to wireless networking). Although it may be cool to be able to connect an Ultracortex headset to the Internet, it does seem a bit silly that you need to connect your Ultra…
  • OK... just to clarify, is that now one LiPo battery with Cytons (for powering both the Cyton and WiFi Shield), and two separate LiPo batteries when using Ganglions?
  • Thanks for the info. I was just concerned that I may have needed to upgrade the capacity of the battery I had, in order to make good use of the headset with the WiFi Shield. FYI, I was only just able to squeeze in the 1000mAh LiPo battery I bought…
  • Yes! I had the same problem on my Windows 8 laptop when trying to use my Cyton board and headset.Many thanks for the solution, will.
  • Hello again. Thanks for the 15% discount; that made my decision to purchase OpenBCI gear easier. After having purchased items, I noticed on the final checkout screen the following line: fbq('track', 'Purchase', {value: '1,005.14', currency:'US…
  • OK, I think that the problem was to do with a $1000 debit limit on my VISA card. I'll try using PayPal instead. Thanks again.
  • Hi William, thanks for that information. I was trying to checkout the aforementioned items from your store using a VISA debit card. However, it displayed the following message: Card was declined I have enough funds in my account to procee…
