tomas_v
tomas_v
- tomas_v
- 18
I am actually using the TCP WIFI API. To set up connection I call POST /tcp with { port: 4202, ip: '192.168.4.2', output: 'json', latency: 200000, } and the device replies with: {"connected":true,"delimiter":…
I checked eeg-pipes and it refers to the https://github.com/neurosity/openbci-observable for obci wifi shield. This one still uses https://github.com/openbci-archive/OpenBCI_NodeJS_Wifi under the hood (actually even the previous one).
@retiutut What do you mean exactly by the driver? I use openbci utilities to get the commands, but I am not using the openbci node sdk, because it has a lot of dependencies which are not compatible with react native
@retiutut Thanks for the reply. I am using it inside react native app, I create a tcp server and follow https://docs.openbci.com/docs/05ThirdParty/03-WiFiShield/WiFiAPI so I make just fetch calls. Then I log data from the tcp server. Yes, it is ki…
