Avatar
togume
togume
Username
togume
Location
United States
Joined
Visits
35
Last Active
Roles
Member
Location
United States
  • Great points, wjcroft! The issue we were running into with the hubs is that as soon as we plugged more than two devices into a hub we would start seeing issues. It's a nice, powered, good branded (Anker) 7x USB 3.0 Type A HUB, but we can only get 2x…
  • @wjcroft - not for what we're using it for... We have a powered 4x hub and we can only take advantage of 2x ports before running into issues and therefore have to use multiple controllers on the computer. Thanks for that link. I'd run across that,…
  • We are also wondering how to interpret the head plot, and did not find any further information on the docs site or forums. Reading the HeadPlot source file helped understand a bit more, but I still don't have a clear picture of how it works or how t…
  • Thanks, @dancingdarwin! Great data points. The issues you mention will definitely be problematic for our work. @wjcroft - I sent this along via the contact us to OpenBCI, but worth noting here: making a wishlist request for a future OpenBCI plug &…
  • @dancingdarwin - thanks for your work on https://github.com/Airan-Lab/OpenBCI_32bit_Library_Wired. Now that the 3.0 firmware is out in the wild, do you have any recommendations for anyone looking to do a wired USB connection to the PC? Do you feel t…
  • 2 for 2. Thanks, William. And likely the right approach is to use the WiFi + longer cables away from the head. Have a lovely night, -Tomás
  • Thanks for the thoughtful reply, William! And thanks for cultivating a great community in the forums as well - i.e. the "nudge" regarding the bricked device comment. Great to see that there's a path to a wired connection, including the USB Isolato…
