sudarshanj645
sudarshanj645
- sudarshanj645
- Bangalore, India
- 27
- Bangalore, India
Bump.
Understandable! I will acquire one of these tomorrow and observe the output trigger from the Optoisolator under an oscilloscope to verify this as per your suggestion. Thank you.
Hey William, I have checked the wiring and the continuity of the circuit and verified it with the picture and the schematic in the documentation. I can verify that once again, to be sure. I can obtain a multimeter on short notice, and perhaps a …
Hey William, Sorry about the previous comment, my screen froze when I was typing and I don't know how the comment got posted, I intend to remove it. To answer your question, NO, the Arudino did not work through the optoisolation system, either. …
Hello William, No, the Arduino triggers
Hello, William. I obtained the suggested part (CNY17F-3) and made the circuit. There are still no noticeable triggers from RPi. I have tried everything possible including checking the wiring, the wires etc., but it does not seem to work. This is…
Hello William, Thanks for the info. I checked the wiring and it seems fine. Could be the IC as you say. I will try to source a compatible part and keep you posted on the developments. Thanks again!
Hey William, Apologies for the late response, wanted to try out what you suggested. Due to the lockdown in my country, I was unable to source the exact part, but I got what I think is an equivalent SMD (Here is the part details - CNY17-2X019T SO …
