Default Avatar
ssub
ssub
Username
ssub
Joined
Visits
2
Last Active
Roles
Member
  • As a follow-up question, is this true for ambulatory recording as well (ECG)? That AGND should not be connected to the subject and BIAS should be used as the Ground instead? When should AGND be used then?
  • After A LOT of testing, I figured out the issue was a bad LiPo battery. Whew!
  • I'm having this same problem with two different Cyton boards, a new one and one that I previously was able to connect to the GUI and get data (a month or so ago). Autoscan works fine for both, but I get a Failed to Initialize board error when I atte…
  • I am currently using a 2000mAh LiPo battery and getting a battery life of just about ~24 hours with recording to SD card. I ideally need to record for 3-4 days. Are there higher capacity LiPo batteries I can use?
  • Did some more tests... everything was working fine for 5 minute recordings, but when I increase to 10 minute recordings, it worked the first time on the 8GB SD card and successive times the recordings became shorter (8 minutes, 1 minute, 2.5 minutes…
  • Hi William, I ran all the recommended diagnostics on the card (filled it up to max capacity, ran H2testw, etc.) and it passed all checks. Today, it no longer unformats itself, but it does stop recording prematurely (instead of 5 minute recording, …
