squadus
squadus
- squadus
- Los Angeles
- 241
- Los Angeles
- Website
- https://www.digitalgreentea.com
- Interests
- Entrepreneurship
Do you know if LabStreamingLayer (LSL) is compatible with Open Sound Control (OSC)?
You will need to add a plugin to the end of your command. For example --add streamer_lsl
Try 'pip install yapsy' Also, if you are on Windows try to run as administrator, otherwise try the sudo command.
This value can be passed in using the Sampling Rate field when you are reading input from LSL, otherwise you can leave it blank
With a Cyton board streaming LabStreamingLayer using Python is extremely simple.
The GUI has a Networking widget which can output LSL. Streaming LabStreamingLayer from Python may work as well.
@wjcroft I have reached out to the developers.
This was very helpful. Thanks!
If you want to see if LSL is running correctly into MATLAB, I would try the ReceiveData function. As for the dependencies, check out the labstreaminglayer repo: https://github.com/sccn/labstreaminglayer
@wjcroft I used an alumni email, and was accepted.
@wjcroft I signed up for the Academic Version.
Thanks again William, I am reading up Machine Learning now as it is kind of putting together what classifiers, modifiers, feature extraction are before I actually perform BCI
Hi William, I have tried the run_readlsl command with both variables, 'SamplingRateOverride' and 'srate_override'. inside of run_readlsl('DataStreamQuery','type=''EEG''','MarkerQuery', '', 'ChannelOverride', {'FP1','FP2','O1','O2'}, 'srate_ov…
I have figured out how to add the channel locations. I am at the point where now when I run the command run_readlsl('DataStreamQuery','type=''EEG''','MarkerQuery', '', 'ChannelOverride', {'FP1','FP2','O1','O2'}, 'srate_override', 250); I r…
When I stream LabStreamingLayer into BCILAB I am running into a warning that 0% of my channel labels match a cap design, and my srate is 0 instead of 250 Hz. The .ced file I created in EEGLAB (using this guide) has 4 channels as I have a Ganglion bo…
Thank you! Quick question about EEG and BCI fundamentals: I know it is possible to pre-process, classify, and visualize real-time EEG data from OpenBCI. I want to be 100% confident, is this same function possible without LabStreamingLayer?
I have built my .ced file and configured it using set_infer_chanlocs. When I run LabStreamingLayer into BCILAB I receive a warning that my cap file can not be found. Do you have any idea why this may be?
Hi William, Thanks again for the help. I am following these two tutorials to configure the channel locations for use in EEGLAB and BCILAB. https://sccn.ucsd.edu/wiki/A03:_Importing_Channel_Locations https://sccn.ucsd.edu/wiki/A08:_DIPFIT
Do you know if we need to use a specific plugin in EEGLAB to configure the 10-5, 10-10, 10-20 channel positions?
Check out this guide for streaming data from LSL and into MATLAB: https://irenevigueguix.wordpress.com/2016/07/22/openbci-lab-streaming-layer-lsl/ As for receiving the data in BCILAB the demo may be of use: https://www.youtube.com/watch?v=Sup2SaJy…
What sampling frequency does the LSL widget output? Is there a difference between Ganglion and/or Cyton with Daisy?
Hi William, Thank you for sharing these guides! They have been a huge help. I am at my University's MATLAB computer lab and after talking to a number of people, I have been getting more familiar with the "Open" part in OpenBCI Sorry about the…
Thank you!
@wjcroft thank you Do you know of any GUI applications that can perform source imaging aside from OpenVibe?
Hello, Does anyone know if the Ganglion can be used on Neuromore? The Ganglion does not use a COM connection, so I am wondering if there is an alternate way to connect EEG data to Neuromore, perhaps the OSC would work? Just getting started wi…
Thank you William for all the help. I really appreciate you and all you do for the community.
Appreciate the help. I have entered the MAC address into the user.py for the port number. How can I get the board to run from this point forward?
Hi William, After looking at the documentation further it turns out that the Ganglion uses the MAC address to connect via ports, not the Linux operating system. https://github.com/OpenBCI/OpenBCI_Python - see under Ganglion. Thanks again …
You will need to use an older alpha of the GUI. I got it working without the BLED and using the CSR instead. Cheers!
I've got Zorin OS running now, and it has Wine installed from the get-go.
