sonali
sonali
- sonali
- ga tech
- 11
- ga tech
The raw data files have a header that clearly states the sampling rate is 250 Hz, but the first column of the data loops from 0 to 255, giving a total of 256 samples per second. Can someone help clarify this discrepancy?
I have the 8-bit board - if you do too, the diode series is CDSU400B. Here are the details on Mouser, which is where I ordered my replacement. Soldering it in fixed the problem. If you have a different board, the diode specifications are given in t…
Hi, thanks for the quick reply! Between the DVDD and GND I am getting only about 1.2 V. GND/AVSS is almost nothing (.01 V) and GND/AVDD is 0.16 V. Pretty sure we have isolated the problem to the diode, which seems blown. When it is bypassed I get …
