skygarden
skygarden
- skygarden
- 6
thank you! if the rev updates i can just adjust the dimensions down the road but this should be great for the moment.
thanks if possible would you be able to tell me the hole diameter and the distance between the side of the board and the side of the hole as well as the distance along that same edge between the approximate middle of the hole and the nearest corner.…
