Default Avatar
shaluska
shaluska
Username
shaluska
Location
Ohio
Joined
Visits
92
Last Active
Roles
Member
Location
Ohio
  • Correct and this is what I did, which resulted in the error messages when attempting to run it in Processing
  • But there isn't an existing file with the name NetworkStreamOutOSC.pde
  • However when I added the NetworkStreamOutOSC.pde file (from the pull) into OpenBCI_GUI folder/libraries and run the program in Processing, it comes up with error message, "Cannot find a class or type named “NetworkDataType”" in console with several …
  • Hello again and thank you for your help from 4 months ago! Revisiting this again. I have opened the code in Processing and was looking to implement the fix but it looks different than the screenshot Richard sent me. According your screenshot, the…
  • Great, thank you for the updates. I'll hold tight.
  • Hi again, @wjcroft and @retiutut I'm just following up to see if you have any suggestions for how to get the FFT data into Max. Thanks
  • Hi William, Unfortunately, I can't print the data because I am receiving an error message with my OSC-route objects that are associated with the FFT data, "OSC-route: doesn't understand 'float'." Even though some of the data makes it through to t…
  • Hi William, Thank you, I appreciate your insight. I believe you're right; Max can deal with UDP directly and that OSC is encapsulated in UDP. I'd prefer to stick with OSC because I'm using the data for audio applications and therefore I've built …
  • Hi Wjcroft, Thank you for the reply. Yes, I am familiar with the document that you linked and it helped me understand how to format other data networking options. Am I not able to transfer FFT data with OSC and only through UDP? I would prefer to…
