severinchik
severinchik
- severinchik
- Kiyv
- 20
- Kiyv
Hi @wjcroft! I adjusted the range of the FFT as you asked and turned off impedances measurement Here is the result (~50 seconds recording) I started the data stream, then moved further from the laptop and then came closer to stop recording - you'…
Impendances were in range ~100-600 kOhm
First 2 are pictures, and the last one is ~one minute screenrecording Now the board works, but amplitudes are high even when I'm far from the electric devices
Hello, guys I run experiments with Cyton alone and this time channels weren't railed. I also tried to switch earclips, so here is initial config performance: https://drive.google.com/file/d/1NoWyUE8mqAwLSxwJgbHSiAaoxmG8KVYM/view?usp=sharing and…
Hello, guys @wjcroft, @retiutut On this video I mistakenly connected the second part of the y-cable to the AGND https://drive.google.com/file/d/1M025D5PyWKB-8qe9cs-8xlgEyi7Kbrzc/view?usp=sharing But with the correct configuration I just got …
Hello, guys @retiutut, @wjcroftx, I'm very grateful for your advice I tried to connect both ear clips to the Cyton board, moved further from the laptop and amplitudes were near 30 uV: https://drive.google.com/file/d/1M025D5PyWKB-8qe9cs-8xlgEyi7K…
Hello, guys @wjcroft , I've checked the instructions you sent I don't have the gold cups I run some experiments and noticed that when Daisy connected to Cyton - all channels are railed, but when Daisy is disconnected the amplitude is huge. I add…
@retiutut, thank you very much for such quick response ok, ping me if you have some news
