Default Avatar
sal
sal
Username
sal
Joined
Visits
26
Last Active
Roles
Member
  • Sorry, no, the proper way is still not working. I rarely post on forums, so I need to become more clear. "Thanks for clarifying that" was referring to the post about Ganglion, and the rest referring to "Did you change ALL the places that the 'a' was…
  • Thanks for clarifying on that. I found 'A' being written in 2 places, sendChannelDataSerialBLE and sendChannelDataSerial, so I tried changing it in sendChannelDataSerial first, then in both. I may try redoing it later in case I messed up. And yes, I…
  • Just writing 0xA0 instead of A in firmware didn't quite work, user.py prints a few lines of data and then gets stuck. I will spend some time later to see if I can get things fixed (the thing is, I am new to this). By the way, in one of the other thr…
  • I am not near that computer at the moment, and didn't test everything so some things may still be off, but at least things displayed with user.py started to look normal. Anyway, as mentioned above, I changed pin definitions, changed begin to begi…
  • Thank you very much William, yes, it turned out to be a different start byte.
  • Thanks for the answer, and pardon my ignorance, but I am using the latest firmware, and just changing serial wiring pins and switching begin to beginDebug (part of newest firmware, which seems like to be designed specifically for this purpose). The …
