s_arty
s_arty
- s_arty
- 72
Hi William, Thank you for replying! Just FYI, I'm running 500000 baud between M4 and OBCI and still 500 sps is the limit Can WiFi Shield give 16k sps? Could I mimic WiFi Shield by another controller to achieve greater speeds?
Winslow, Thank you for the nice tutorial! I've done something similar with OpenBCI debug firmware. There is some description of the interface: https://docs.openbci.com/docs/02Cyton/CytonSDK#channel-setting-commands The main difference is I'm usi…
Hi guys, Just my two cents. I was not able to get seamless data out of the SD card.(even 250Hz) The problem is somewhere in implementation of SD stack. Every so often the SD card takes ~0.3 sec to record the data, which leads to the gap in the lo…
Dear William, Thank you for your reply and I thought I resolved this, but looks like I'm lost in weeds... I took the interpret24bitAsInt32 function from http://docs.openbci.com/Hardware/03-Cyton_Data_Format and created simple sketch: p…
Hi William, Thank you for your reply! I have a couple of more questions.. 1. Looks like we should get 250 samples per second, but all the log files have 256 samples per sec. Should I normalize the data or it's just a counter and I should …
Thank you William, Yes, you're right it's plenty, I lost x10 as usual... Anyway, just if someone has similar question, the answer is: 128 Gb works, needs to be formatted as FAT32 (not exFat, as windows tries to format if it sees the size larger…
Hey Jeff, Thank you for the hint! Tibor's project looks really promising, I'll take a look and I'm so excited that somebody else has done some heavy lifting You really made my day, thank you! Please, take a look at the following post here:…
Sorry for the delay with the answer.I've seen several people confirmed this. Unfortunately, I wasn't able to store any data on SD card and created the following thread: http://openbci.com/index.php/forum/#/discussion/1744/what-s-the-maximum-siz…
Thank you for the answer! Are there any plans to proceed with this approach? I know, Cyton has a debug mode in v3, where D11 and D12 are an external UART. This is good enough for me right now, but you're welcome to throw any suggestions my wa…
Hi Jeff, I like your plan To be honest, I have similar plan I've received a Cyton board and trying to use it as a sensor for sleep research as well. In my case it's lucid dreaming. Luckily for me, my board has a debug mode (in v3.x.x firm…
Hi there, people reported that this is possible, I'll try these steps asap and let you know about the result with some confidence. Thanks
Hi Jeff, Are you trying to connect Cyton, 32 bit board? Any luck with SPI and Teensy, so far? I like this idea. Another approach would be to modify the firmware slightly to run UART on pins D11, D12 (breaks SPI, so I assume, you'll have 8 cha…
