Avatar
ryans
ryans
Username
ryans
Joined
Visits
406
Last Active
Roles
Member
  • @pushtheworld Dear AJ, No, I could not solve how to implement "averaged earlobes as reference" on the firmware side of the ADS1299.  According to the data-sheet, it is certainly possible.  Can you have a look?  If all you wish to do is phy…
  • Dear William, I could use a channel to record the other earlobe, but then I believe I would need record both earlobes in order average them together offline as reference.  Now the methods are getting messy, as I would still need to send someth…
  • I wish I did.  I am about to conduct a study, and afraid journal reviewers will criticize or reject my methods if Cyton is wired according to tutorial.  Can anyone help us?
  • Dear William, I did have a look at the hardware settings in Processing GUI.  There are the options for each channel:  BIAS_MEAS, BIAS_DRN, BIAS_DRP I suppose I could sacrifice two channels, one for each earlobe, and assign BIAS_MEAS to them.  …
  • Hello William, Averaged Earlobes or Averaged Mastoids as reference are the best practice in my line of ERP research.  This is typically done on the the software side in EEGLab.  Considering the ADS1299 is capable of doing this internally, it would…
