robertoostenveld
robertoostenveld
- robertoostenveld
- 17
I have done some further investigations, still no solution. But let me report the details. As reported before, the OpenBCI Hub application does not print extra debugging information when started from the command line. I looked into the WiFi shie…
Hi @retiutut, Please find the log file at https://justpaste.it/7fyte (I am not allowed to paste it here, the message body would get too long). It contains three system initializations, one of a ganglion board without wifi shield, two of (ano…
Thanks. I am currently traveling and don't have the OpenBCI hardware with me, so cannot test and report on details. I will report back as soon as I am home.
Let me give an update. I tried it with another WiFi shield, which resulted in the same failure in the OpenBCI GUI. Furthermore, I tried it with the OpenBCI_Python code, which also failed mac011-3> python stream_data_wifi_high_speed.py Welco…
I had a similar problem, i.e. dongle not being recognized. With the help of Joel I was able to resolve it. Let me first describe the problem, then the solution. The dongle of my 8-channel 32-bit OpenBCI (Cynthon) board stopped working and did not …
