rmib200
rmib200
- rmib200
- Bolivia
- 13
- Bolivia
This is my procedure in order: (During the Cyton radios programming tutorial) * Download Arduino 1.5.8 BETA -> Download and extract OpenBCI_RFduino -> Download and extract OpenBCI_Radios Firmware -> Connect the pins of the breadboard c…
yes
@rmib200 said: From the OpenBCI_GUI I've tried to check the status and got this message: "Error reading from serialport. Try a different port?" I've tried changing the port and using a different computer but the error stills the same.
Yep, I also post the error I got when I verify the RFduino on the GUI on my last post.
I tried re-doing all the steps in the tutorials and I got an Error during the Cyton Board Programming. I've put the board on Bootloader mode, try to upload the code of the DefaultBoard script and got an error that says "No target found." At the mome…
I'm not on the first step. I've completed the steps on the Cyton Radios. Just sending the pic to confirm that. I'm trying to upload the Cyton Firmware. Is there a way to check if the previous steps where done correctly? I don't know anything about h…
I would say that all the steps where succesful until this last one. Is there a way to make sure that the Pass Thru Radio Firmware was correctly uploaded to the Cyton Board?
Hi!! I managed to get this far. I followed the tutorial for the usb dongle and now I'm trying to update the board. With Arduio 1.8.15. But I get this error. The board still is not recognized by the GUI. It seems that the problem arises when the co…
@wjcroft Hey there! I've been trying to follow the guide but I'm stuck in one step. ---In the Arduino IDE 1.5.8 go File-->Examples-->OpenBCI_Radios-->RadioDevice32bit which will launch the Device firmware. I unzipped the folder with the …
@wjcroft Do I need to upgrade to v. 2. 0 first and then upgrade to v 3.0? or can it be upgraded directly to v.3?
Btw, I tried with an older version of the GUI v3.4.0 and also no luck
This is the Log that I get when using GUI v.4.2.0. I guess the Cyton firmware is v1.0.0 Console Log Started at Local Time: 2021-03-24_14-39-30 Screen Resolution: 1366 X 768 Welcome to the Processing-based OpenBCI GUI! For more information, pleas…
Hello! My name is Manuel and I'm currently a post grad student in Bolivia. With a group of students in my university (Universidad Católica Boliviana) we founded a NeurotechX Student Club about a year ago. Right now, our goal is to learn and train o…
