rick
rick
- rick
- 0
Hi Chip, thanks for your answer. I've set #define SCK_MHZ (8) in ADS1299Manager.h to get a higher SPI speed. I've also set the sampling rate of the ADS1299 to 500 SPS with this: ADS1299::WREG(CONFIG1,0b10010101); delay(1); in the initiali…
http://buildandcrash.blogspot.de/2013/12/eeg-design-time-for-something-totally.html
Hi, as you say yourself, _GND is not connected to AGND in the schematics. They are isolated from each other by the ADUM6010 chip. I can send you the PCB layout i made and you can check out the in PCB grounding Comment by rick June 2014
Hi erisian, I am currently going to do the same as you! What progress did you make so far?
Got it working! The fault was at my program, it needed some threading to get all of the data.
What do you mean by -GND? Can't find it..
