richardnaar
richardnaar
- richardnaar
- Tartu
- 12
- Tartu
Thank you! You are right that a transition within one 4-ms sample does not establish the sensor’s actual response time. I don’t currently have paired onset/offset flip timestamps for that recording. We are, however, planning to compare the OpenBC…
One additional observation is that the detection threshold does not seem to explain the shorter measured durations. I tried a wide range of thresholds on the RAW trace and obtained the same pulse boundaries and durations. The signal is almost square…
We are using the Photoresistor Module supplied with the current OpenBCI External Trigger Add-on for the Cyton, connected to D12 exactly as described in the OpenBCI guide. We have not added any external components or filtering. I checked the produ…
Thank you, that makes sense. The stimulus was presented using a recent version of PsychoPy (2026.1.3). In an earlier version we timed the pulses using elapsed time rather than frame counts, and that indeed produced intervals that were consistentl…
Thank you! I checked the files more closely and the code path you pointed out seems very consistent with what we are seeing. The BDF header contains 12 signals in total: EEG 1–8, Accel X, Accel Y, Accel Z, and BDF Annotations. EEG 1–8 and Accel X…
