refurbished
refurbished
- refurbished
- 12
"There was an update to both of those firmwares over the summer. " What are the advantages when I update both RFduinos on the dongle and the board? I have a RFduino Kit.
I've done some research on the streaming-transmission thing (8 ADS1299 Channels in 31 Bytes) and found the following: a) the PIC32 Processor is sending exact every 4 ms. The transmission takes 3 ms, so 1 ms is left free. b) the radios follow this…
First had to start a praise session, then I discovered my error, now downloaded, and it runs again (Blue LED is ON!) I had to connect to: OpenBCI 32 Bit Board Pin 3 RFduino -> Dongle FTDI_TX OpenBCI 32 Bit Board Pin 4 RFduino -&g…
Or could somebody make a image of his system with picit3 or the chipkit pgm with MPLAB IPE (the Flash-Program software) and load the image to github (and/or please send it to my gmail: asec14) for use with the MPLAB IPE by using the p…
We get the similar error: avrdude: verification error, first mismatch at byte 0x125c 0xff != 0x01 avrdude: verification error; content mismatch Tried more than 15 times and did not work. Put the antennas close together, wrap ev…
