qijia
qijia
- qijia
- 43
Thanks! So the conclusion is there is no way to keep the floating channel always open and reading signals?
yeah i know it is not an ideal way, but just curious if it is possible to do so even if it is a bad attempt. Also if we "look at your active channels that are connected to the subject. Both time series and FFT." then the original signal will inevit…
Thanks for the reply! So there is no way to keep the floating channel always open and reading signals? I would like to know the environmental noise to some extent.
It seems that if we only want a 1-channel ECG, 2 electrodes are enough to get the ECG signal. The ground connection is just for mitigating the common noise? Thx!
OK. Thanks for the quick reply!
I bought a new Cyton board and tested it. I got the same phenomenon. Then I realized that it is not due to the board. After some testing, I found that it is because I did not connect to the ground. Although I am not sure why this is causing the disa…
Thanks for the reply! I'll test what you suggested and if still does not work consistently, I'll email for an exchange. I think we bought it within a year.
Hi thanks a lot for the quick reply. I am not sure what do you mean by 'intermittent electrode cable or connector'. I tested the cables and also tried to use different cables. It turns out at channel 5, the phenomenon will happen but not on other…
Hi there, I am plotting the raw data out from the cyton board w/o adding any filter. Why the voltage will keep increasing over time? Is that due to the board? Thx
Thx. After i got the new one, it worked!
yes. Tried all of them but with no luck. and here is my log file: Console Log Started at Local Time: 2022-01-25_15-02-37 Screen Resolution: 2560 X 1440 High-DPI Screen Detected: true Operating System: Mac Welcome to the Processing-based OpenBCI G…
thx. I just emailed them. Just want to get a reply asap, so i want to see if there is any solution here.
i have exactly the same issue. Have you solved this problem? thx
