qdewolf
qdewolf
- qdewolf
- 119
it is suddenly working. I will post some kind of recipe when I finish making it smooth.
when I enable serial1 with the begin command the serial1 and serial0 writing and printing commands work fine, but when you set the line "while (!(OBCI.isDataAvailable())) {} // wait for DRDY pin..." it never exits the while loop. if I put a print …
actually I spoke prematurely. the line "while (!(OBCI.isDataAvailable())) {} // wait for DRDY pin..." fails to ever pass when all I turn on is the Serial1.begin line?
stunning!! it works the ChipKit file in windows is located C:\Users\#username#\AppData\Local\Arduino15\packages\chipKIT\hardware\pic32\1.1.0\variants\openbci\Board_Defs.h I will post here about final setup and performance for Android use
this did not work. 11 stays low and 12 stays high even if I comment out all of the serial1 references from the ino
I figured out that there has to be a second delay between the 2 begins and now the board does not lockup but I still can't get anything to appear using Serial1.println("123"); Serial0 works fine but nothing is coming out of D11 and D12. I even tried…
I looked through that entire thread and I have all of the correct settings. Even just calling Serial1.begin(115200); causes the board to stop.
I did try that by sending data to Serial1 but even calling begin on serial1 causes the board to crash.Serial1 must be not setup correctly somehow?
do I need to do anything in the ino to setup the pins to be serial1 or will just referring to it automatically set it up?
If I could just get the pickup points that would give me a serial stream I could tie into that would be great. I believe that two fo the D# points on the board would be accessible as serial1 or are the serial0 would work?
are D17 and D18 addressable as a serial port? the docs indicate these pins are serial i/o? the links above use an older board with different labeling and i cannot fined the place to connect to or if i need to create a new serial port in the code on …
is the serial data going to the rfduino that same as the rfrx and rftx tabs on the bottom of the board?
the problem with the otg solution is the phone will be in a gearVR which does not expose the data connection (only the power connection)
