piotr_s
piotr_s
- piotr_s
- Poland
- 80
- Poland
Thanks I've already contacted seller from China. Since, this is open source hardware , maybe someone experienced similar issue. I don't expect solution, but maybe a tip what might have happened that I get response ADS1299 Device ID: 0x00
Hi, there I managed to load firmware 3.1.1 correctly (I had to use windows ) and now I am back to tarting point, so with answer to command ? like that: python3 main2c.py Connected to /dev/ttyUSB0 at 115200 baud. Sending 'v' command to check fi…
So I decided to give a try to write firmware again (3.1.1) following official guide https://docs.openbci.com/Cyton/CytonProgram/ after ups and downs I managed to load firmware with Arduino IDE, but now my board doesnt recognize commands.... impo…
I further checked in with command v and ? here is output Connected to /dev/ttyUSB0 at 115200 baud. Sending 'v' command to check firmware version... Firmware Version Response: OpenBCI V3 8-16 channel On Board ADS1299 Device ID: 0x00 LIS3DH…
Brilliant !!! Thank you very much , I was in hurry reading it and missed that completely...
Thank you :-) I would add one more, telling what to do with Y-spliter cable: https://shop.openbci.com/products/ultracortex-mark-iv Still, in case of CEEGrid, do I need to use that Y-splitter cable? CEEGrid set seems to contain referencial electr…
thanks for sharing :-)
