petewall
petewall
- petewall
- 107
Worth mentioning. I tried the Ganglion on a Windows machine I have here and it looked a lot like how the Cyton looked on my Mac. It does appear to be an issue with Macs and Ganglions.
@biomurph I downloaded the 3.3.0-beta1 release. Is this dongle the same one that was bundled with the Ganglion (which says "CSR 4.0" on top)? I cannot see the Ganglion device now. Here is the device information for the USB dongle: And here's…
Just to follow up with this*. The OpenBCI GUI does have a band powers widget. That's really useful for seeing those values in the GUI. For my use case, I really needed some code to capture these values without needing to run the GUI. My first a…
After that, I was able to get the firmware uploaded to the Ganglion and its working now. Light Blue now shows: Manufacturer Name: openbci.com Model Number: Ganglion Hardware: 1.0.1 Firmware: 1.1.0 Software: 2.0.0
That was it! Thanks everyone. I followed the directions to put the special code onto the Cyton dongle and then flashing the Ganglion worked. For anyone else, here was the steps I took: Setting up the Cyton dongle: 1. Download Arduino 1.5…
@wjcroft. Yep, those are the steps I'm working through now. The RFDuino board is not listed in the boards list and the steps on that page instructs to unzip a directory inside the Arduino directory itself. This doesn't work on newer versions of t…
@pushtheworld Correct. I didn't upload any custom code to the Cyton dongle. I'm trying to use the steps from http://docs.openbci.com/Hardware/06-Cyton_Radios_Programming_Tutorial#cyton-radios-programming-tutorial-uploading-device-firmware-to-cyton…
Yes, the dongle switch is set to GPIO6.Yes, there is a 0.1uF capacitor between the dongle's EXT_RST pin and the Ganglion's reset pin. When I swap the TX and RX pins, this is the new error message: Timeout reading from uart. fail.......fail....…
We found it. Turns out, we missed the two 2-pin headers by the 90° electrode connections. User error, sorry to bother!
Strange. It's back to saying "No daisy board present". I'll take a look at the solder joints and see if anything is wrong. To clarify, there are two headers to solder: The 8-pin header with DVDD - CSC, and the 2-bin header with BIAS and AGND? …
I'm sure this is the first time that we've tried to use it.
When I got the Daisy board, we had to solder on the headers. Everything works fine without the Daisy. I just tried again, and it's doing other strange things. It starts up fine with 16 channels, except channels 9-16 are giving the same output as…
@wjcroft Thanks! I don't know how I missed that.
Will we be able to use a few of the GPIO pins on the Simblee? I would like to be able to add components for external triggers and digital outputs.
