Default Avatar
parguello
parguello
Username
parguello
Location
USA
Joined
Visits
19
Last Active
Roles
Member
Location
USA
  • @julienConscious said: Hi @parguello, thanks for sharing your experiments. I see values around 100microV (10^-6 V) in your graph and this range of values looks quite normal to me. Do you feel like the signal responds to your actions (blink…
  • W/ the help of the folks at BCI2000 forums, I was able to determine that the author of the OpenBCIADC Source module erroneously named one of his parameters, resulting in some confusion of setting the channel gains. It seems as if the channel gains a…
  • Good morning, I've decided to switch to using the ThinkPulse Active Electrodes for my project involving the third-party software suite BCI2000. Currently, I'm running into some issues w/ setting gains and would appreciate any input on the ThinkPu…
  • Figured I'd update this thread w/ some findings since I'm in the neighborhood. Never got in touch w/ the original authors of the code, but I've had some time to figure things out: * My understanding is that OpenBCI_Module is for use w/ the Open…
  • I'll do just that and report back any findings, in case anyone runs into similar issues. Thanks for the assist, William.
  • It appears we shared the same instinct: default to using the module that has the latest support Trouble is, when I used the OpenBCI_Module I received all kinds of errors and anomalous readings. The matter is further complicated by the fact tha…
