openoli73
openoli73
- openoli73
- germany
- 57
- germany
Okay, in amplitude, it can only be muscle artifacts. I now have the headband slightly higher. It seems to work with a bandpass of 3-30.
If only someone could explain to me how the extremely strong deflections can get into the file. I would have to see them in the GUI too or is there a normalizer built in?
I would like to continue working? Where is @Retiutut? When will he be back? Can someone send me a bdf+ file from Cyton or attach it here? Thank you
I have now done a test with EDFbrowser. I also get an error message about the data in visbrain. BDF file detected Setting channel info structure... Creating raw.info structure... Reading 0 ... 5749 = 0.000 ... 22.996 secs... Data succe…
@retiutut Can you send me a sample photo with electrodes on my head? Maybe I also destroyed the ADS1299 statically or thermally? Can you send me a sample photo with electrodes on my head? Maybe I also destroyed the ADS1299 statically or thermally?…
The connections weren't the problem. Can I check the firmware version to see if it is up to date?
The high values are normal for the input range of the ADS1299. That no curve is displayed without filter is also normal. It is due to the phase position. I found the main problem now. I had soldered some wires to the board and plugged some. The b…
Thank you for pointing that out. @retiutut What I don't understand is that when I turn off the BP filters there should still be a signal visible in the TS. But why is it empty? At 10000µV you sometimes see a line, but you don't see an answer to e…
One problem was the fan in the PC, which was always turning up every 5 seconds :-)
It's working. The last big values probably come from shutting down. They are only at the end of the recording. Super. Many thanks for the good support.
Okay, now it almost looks very good with Notch 50 and Band 5-45. Just these extreme rashes. Now I have WLAN again, but with a European instead of an American standard ;-). I will search even further. There seems to be no problem with the file or the…
Okay, thanks. Are the hardware settings right?
WIFI was on the laptop. I only switched off the routers. But the high values in the diagram (BDF) are still there.
Now I have no more interference. I have switched off the WLANs.
I have now applied a bandpass 1-45 Hz. Result as in the photo. The data is saved without the GUI filters?
Okay Many Thanks
Hello, I am using GUI 4.1.6 and unfortunately I have big problems with the BDF files with visbrain and EDF browser.
One of the nice things about writing the data in blocks is that once the block is written, it is on the card. In other words, if you create a file that allocates 30 minutes of record time and then stop your recording after only 15 minutes (by resett…
I didn't replace the folder and after installing the package, I started the GUI. So the hub was started automatically. Everything runs fine.
is working, many thanks
https://github.com/electron/electron/issues/1518 app is ready
./OpenBCIHub ./OpenBCIHub: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
Sudo doesn't work either. I tried npm now but got a lot of bugs. I need to take another look at this in peace.
