omarclaflin
omarclaflin
- omarclaflin
- USA
- 23
- USA
- Website
- https://www.researchgate.net/profile/Omar_Claflin
- @claflin_o
Seems to be an issue with setting pinMode(11, INPUT) This is present in both modes that aren't working (analog and digital) and absent in all the modes that are working. Removing this line or replacing it in the OpenBCI_32bit_Library_definitions.c…
@Conor, @pushtheworld, @techsupport. Update: I ran all the codes a couple times (so I'm reasonably sure that I'm consistently getting these responses). Using this code: shield = bci.OpenBCIWiFi(sample_rate = 1000, ip_address = '192.168.4.1',…
@techsupport Thanks AJ. Lemme know if I can try/reproduce anything for clarity.
Hi William, Thanks for the circuit explanation and its interaction with the Cyton board. Other two issues logged in GitHub. Much appreciated, Omar
