nushaab
nushaab
- nushaab
- Toronto, ON
- 56
- Toronto, ON
@stff1950 said: I think we have same issue. Should we also call to customer support? I would advise in doing so if you have tried the tips William had previously mentioned.
Thanks William, I've gone ahead and reached out to customer supports. Thanks for your suggestions.
I have ruled out a battery issue for the time being, since I have attached a new JST connector and battery pack which I soldered which is providing the Cyton board with sufficient power, while the board still fetches a BOARD_NOT_READY_ERROR. Upon…
For reference, here is the console log output where I launch the GUI, use the autoscan feature, connect to Cyton via COM3, then attempt to start session. Console Log Started at Local Time: 2022-04-21_16-31-28 Screen Resolution: 1920 X 1080 High-D…
After booting up the board this morning, the same issue occurred. But the blue on-board LED was fluctuating in brightness. I checked the input voltage at the JST pin and it was fluctuating along with the LED brightness. Eventually, the LED stabilize…
I also wanted to note that I tried the 'manual' serial connect feature on OpenBCI GUI. Auto-scan fetched a message that reads, "Success. Cyton and Dongle are paired. Ready to start session!". After pressing 'Start session' shortly afterwards, I agai…
Thanks! Looking forward to the next version of the GUI.
Thanks for the suggestion William. It seems as thought the structure of the CSV file may have changed, as the columns necessary for plotting the analog data were located in different columns. It seems as thought the Python script I have used from th…
