nosa
nosa
- nosa
- Iraq
- 61
- Iraq
Hi, @retiutut the data is streaming in openBCI_GUI, but the speed is very fast. GUI plots the data in 2 seconds instead of 20 seconds: how can I resolve this issue?
Hi, The problem resolved. I put the codes for this issue in below link: https://github.com/nosa999/brainflow
I added my codes in files of ganglion in Brainflow for adding my device, and I started streaming data and I received it in OpenBCI-GUI and it runs for some secondes but the following error is occured.
Hi, I add my own BLE device to openBCI-GUI but when it starts to stream data after a few seconds the following error is occured.
Thank you for your response. there are other ways in which you could receive your device data stream, do signal processing, display graphs, etc. That do not involve the complex mods needed in Brainflow and GUI source code. For example, there a…
Hi, Thank you for your response. we are trying make our own board and connect it to OpenBCI-GUI for showing the signals. Our device use BLE for connecting to GUI. So we follow the ganglion method in openBCI-GUI. In this way, we found ganglionScan.d…
Thank you for your responses @wjcroft , @retiutut I know BITalino's software and codes. Just I like to know how OpenBCI-GUI finds ganglion devices with BLE. and I want to make a new hardware (it is not BITalino, and BITalino just was for my first e…
Thank you for your response, I am developer and I want to make openBCI_GUI a software that visualize my hardware signals, for this issue I want to make it a software can connect to BITalino at first. Does the software use ganglionScan.dll for findin…
