nk
nk
- nk
- 39
Got the verification read page error, device now powers on and seems to work fine. If the code didnt upload properly would there be any symptoms or would the device simply not power on?
I have successfully uploaded the latest rfduino firmware onto both the dongle and board. I now get through the upload process every time but get the same address error on verify. I have tried a dozen times and followed advice on other thread ab…
Meant the RFduino USB Shield
So I take it that the ftdi friend indeed does come with the headers already soldered on? Also, if I use the ftdi friend, do I still have to use the breadboard to connect the jumpers to the openbci board or is the breadboard only necessary when us…
Yes, I used the number that was labelled on the anti static bag that came with the board. Is there anyway to upload the rfduino code onto the board without having to solder anything? Thanks again. . .
Thanks for the quick reply. I did not upload the device firmware to the board since it seemed to require hardware modification beyond my current abilities. Before I uploaded the firmware to the dongle I did change the channel in one line of …
So, I tried to to update the firmware on my 32bit board and now no blue light on power on. I followed the instruction for using the arduino ide. It would start uploading then program flash failed. I tried many times and then after reading this…
