nj
nj
- nj
- Santa Cruz, CA
- 16
- Santa Cruz, CA
So, it seems this has been discussed before in multiple places. For example: https://github.com/OpenBCI/OpenBCI_GUI/issues/129 My understanding is now that the timestamp (in the text file in "SavedData") is set by the PC. Is this timestamp inheren…
Sorry, for missing your comment @pushtheworld. I don't have this problem anymore! Thanks.
The Cyton kit was purchased around May this year. I could not figure out how to get the firmward revision level. However, I took a closer a look at the data. As I said before, the time stamp does not progress evenly. There are 10-20 rows with ex…
Yes, I had installed FTDI drivers from the page you are referring to. I re-did it again to be sure. So, when I go to the Windows Device Manager at look at the Port COM settings it says "Driver: FTDI", "Driver Date: 8/16/2017" and "Driver Version: 2.…
Hi Pushtheworld - are you saying that what I experience right now with large gaps is currently the regular expected behavior? (I hope not...)
(Had to take a break in this work. Back now...). I adjusted the latency setting to 1 as your tutorial described. It led to some improvement but the data is still coming in bursts. Prior to the change there were gaps of about 0.47 seconds and the gap…
Oops! So, I followed the Cyton instructions. The first steps works well. I get to the point where I have the OpenBCI GUI software up, it shows "COM5" and I get a "Success" Status. When I click "Get Channel" I see that I have channel 20. Now I click…
